Einleitung
You will need a phillips head screw driver, needle nose pliers, solder, and a soldering iron to complete this task. Before opening the device, ensure that there is no power to avoid damaging the electronics or harming yourself.
Was du brauchst
Locate the terminals coming off of the backside of the LED lights. Cut the terminals to remove the light from the frame.
Insert the new LED light into the frame. Use the solder and soldering iron to reconnect the terminals to the new lights.
