Zum Hauptinhalt wechseln
Ecovacs DEEBOT D35 Motherboard Replacement
Was du brauchst
  1. Ecovacs DEEBOT D35 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Flip the D35 onto its back.
  2. Ecovacs DEEBOT D35 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the 9 screws with a PH2 Phillips screwdriver on the underside of the D35. The screws are:
    • 7 x 14mm screws
    • 2 x 10mm screws
  3. Ecovacs DEEBOT D35 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Use spudger or plastic opening tool to separate the Deebot backside
  4. Ecovacs DEEBOT D35 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Carefully lift the back cover from the body of the Deebot
  5. Ecovacs DEEBOT D35 Motherboard Replacement: Schritt 5, Bild 1 von 2 Ecovacs DEEBOT D35 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • There are 5 cables that need to be carefully disconnected before completely disconnecting the back cover:
    • The 5 cables two blue cables on the front left and right side (located next to the sensor). Represented by the red arrows.
    • Multicolor ribbon in the front center. Represented by the blue arrow.
    • Two (black and red) two prong adapter connected to the motherboard. Represented by the green arrow.
  6. Ecovacs DEEBOT D35 Motherboard Replacement: Schritt 6, Bild 1 von 3 Ecovacs DEEBOT D35 Motherboard Replacement: Schritt 6, Bild 2 von 3 Ecovacs DEEBOT D35 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Locate the 3 screws on the motherboard:
    • 2 x 14mm screws
    • 1 x 10mm screws
  7. Ecovacs DEEBOT D35 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the screws from the motherboard with a PH2 Phillips Head Screwdriver. The screws are:
    • 2 x 14mm screws
    • 1 x 10mm screws
  8. Ecovacs DEEBOT D35 Motherboard Replacement: Schritt 8, Bild 1 von 2 Ecovacs DEEBOT D35 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Locate and disconnect 12 cables bundles connected on the motherboard
  9. Ecovacs DEEBOT D35 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Carefully disconnect the motherboard from the Deebot body.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 12-2, Eyestone Spring 2017 Mitglied von USF Tampa, Team 12-2, Eyestone Spring 2017
USFT-EYESTONE-S17S12G2
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 14
Insgesamt: 2,716
