Einleitung
This guide will show you how to remove a defective vacuum motor on the Ecovacs DEEBOT D35. To replace it, install a new one by follow these steps in reverse.
Was du brauchst
Lay the Deebot face down so you have access to the battery compartment. Remove the battery.
Locate the 9 screws that secure the back cover. Remove with a PH2 Phillips Head Screwdriver. The screws are:
7 x 14mm screws
2 x 10mm screws
Carefully lift the back cover from the body of the Deebot to expose the internal wiring harnesses.
There are 5 wiring harnesses that need to be disconnected before completely removing the back cover.
There are two blue wiring harnesses on the front left and right side (located next to the sensor). They are represented by the red circles.
There is a multicolor wiring harness on the front center. This is represented by the orange circle.
Two black and red wiring harnesses are connected to the motherboard. This is represented by the yellow circles.
Remove the screws from the vacuum motor body with a PH2 Phillips Head Screwdriver. The screws are:
4 x 10mm screws
3 weitere Nutzer:innen haben diese Anleitung absolviert.
