Einleitung
The DEEBOT model N97S did no longer hold a charge. Replacement batteries are sill readily found online and fairly easy to change,
Was du brauchst
Here is the DEEBOT DN622.11 also know as a N79S.
Turn it over to have the underside exposed
Locate the two Phillips head screws that hold the battery cover in place
Unscrews the two Phillips head screws
Remove the battery cover
Note position of the battery in the battery compartment
Lift the battery out of the compartment
Disconnect the battery connector by squeezing the tab on the female end of the connector. The battery can now be replaced.
To reassemble your Deebot, follow these instructions in reverse order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
