Zum Hauptinhalt wechseln
Ecovacs Deebot 900 Battery Replacement
Was du brauchst
  1. Ecovacs Deebot 900 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove all the brushes from the Deebot.
  2. Ecovacs Deebot 900 Battery Replacement: Schritt 2, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Ecovacs Deebot 900 Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery cover.
  4. Ecovacs Deebot 900 Battery Replacement: Schritt 4, Bild 1 von 1
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Ecovacs Deebot 900 Battery Replacement: Schritt 5, Bild 1 von 1
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
Great guide except no information on where to actually FIND a battery for this thing
Chris Staley - Antwort
Where can replacement battery packs be acquired from?
Larry Smith - Antwort
You can find the battery at Taobao online shopping
Jimmy - Antwort
Amazon also sells them. Make sure to get one for the correct model though (there are alot of them)
Kevin Dunn - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 21
Letzte 7 Tage: 103
Letzte 30 Tage: 420
Insgesamt: 22,299
