Zum Hauptinhalt wechseln
Ecovacs Deebot 900 Motherboard Replacement
Was du brauchst
  1. Ecovacs Deebot 900 Motherboard Replacement, Front Bumper: Schritt 1, Bild 1 von 2 Ecovacs Deebot 900 Motherboard Replacement, Front Bumper: Schritt 1, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  2. Ecovacs Deebot 900 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the black strip on the bottom of the bumper.
  3. Ecovacs Deebot 900 Motherboard Replacement: Schritt 3, Bild 1 von 2 Ecovacs Deebot 900 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Carefully lift up the bumper untill it pops out of place.​
  4. Ecovacs Deebot 900 Motherboard Replacement: Schritt 4, Bild 1 von 2 Ecovacs Deebot 900 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
  5. Ecovacs Deebot 900 Motherboard Replacement, Bottom Case: Schritt 5, Bild 1 von 2 Ecovacs Deebot 900 Motherboard Replacement, Bottom Case: Schritt 5, Bild 2 von 2
    • Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
  6. Ecovacs Deebot 900 Motherboard Replacement: Schritt 6, Bild 1 von 2 Ecovacs Deebot 900 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Insert a Jimmy into the seam and work all the way around the robot.
    • Disconnect the two cables and remove the bottom case from the device.
  7. Ecovacs Deebot 900 Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove the two black screws holding the motherboard in place.​
  8. Ecovacs Deebot 900 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Carefully remove the ribbon cables connected to the top of motherboard.
    • Keep track of where the cables connect to the motherboard.
  9. Ecovacs Deebot 900 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Remove the last three ribbon cables on the underside of the motherboard.​
  10. Ecovacs Deebot 900 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Lift the motherboard out of the Deebot and remove it from the device.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Any suggestions on purchase options?
Curtis Tyler - Antwort
vakum ozmo 900,hidup terus mati,lampu led juga mati,switch masih posisi on
markus arif - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 39
Letzte 30 Tage: 192
Insgesamt: 7,131
