Zum Hauptinhalt wechseln
Einleitung
The Ecovacs Deebot 900 is an autonomous vacuuming robot. If the wheels are jammed, the Deebot will not be able to clean around your house. Use this guide to replace the wheel of the Ecovacs Deebot 900.
  1. Remove all the brushes from the Deebot.
    • Remove all the brushes from the Deebot.
  2. Using a Phillips #0 screwdriver, remove the two 12.25 mm  screws holding the battery cover in place.​
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Remove the battery cover.
    • Remove the battery cover.
  4. Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
  6. Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​ Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  7. Remove the black strip on the bottom of the bumper.
    • Remove the black strip on the bottom of the bumper.
  8. Carefully lift up the bumper untill it pops out of place.​ Carefully lift up the bumper untill it pops out of place.​
    • Carefully lift up the bumper untill it pops out of place.​
  9. Disconnect the two cables connecting the bumper to the body of the Deebot. Remove the front bumper from the device.
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
  10. Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case. Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
    • Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
  11. Insert a Jimmy into the seam and work all the way around the robot. Disconnect the two cables and remove the bottom case from the device.
    • Insert a Jimmy into the seam and work all the way around the robot.
    • Disconnect the two cables and remove the bottom case from the device.
  12. Using a Phillips #00 screwdriver, remove the two black screws holding the motherboard in place.​
    • Using a Phillips #00 screwdriver, remove the two black screws holding the motherboard in place.​
  13. Carefully remove the ribbon cables connected to the top of motherboard.
    • Carefully remove the ribbon cables connected to the top of motherboard.
    • Keep track of where the cables connect to the motherboard.
  14. Remove the last three ribbon cables on the underside of the motherboard.​
    • Remove the last three ribbon cables on the underside of the motherboard.​
  15. Lift the motherboard out of the Deebot and remove it from the device.
    • Lift the motherboard out of the Deebot and remove it from the device.
  16. Using a screwdriver or tweezers, remove the spring by lifting the spring and pulling it off one side.
    • Using a screwdriver or tweezers, remove the spring by lifting the spring and pulling it off one side.
  17. Using a Phillips #00 screwdriver, remove the four screws holding the wheel assembly in place. Using a Phillips #00 screwdriver, remove the four screws holding the wheel assembly in place.
    • Using a Phillips #00 screwdriver, remove the four screws holding the wheel assembly in place.
  18. Remove the wheel cover.
    • Remove the wheel cover.
  19. Using the Phillips #00 screwdriver, remove the three screws holding the side brush motor in place and lift the brush motor up. Using the Phillips #00 screwdriver, remove the three screws holding the side brush motor in place and lift the brush motor up. Using the Phillips #00 screwdriver, remove the three screws holding the side brush motor in place and lift the brush motor up.
    • Using the Phillips #00 screwdriver, remove the three screws holding the side brush motor in place and lift the brush motor up.
  20. Lift up and remove the wheel assembly and the attached sensor (black cable). Lift up and remove the wheel assembly and the attached sensor (black cable).
    • Lift up and remove the wheel assembly and the attached sensor (black cable).
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Thanks, it helps a lot
Agoston David - Antwort
I have an OZMO 930 that the left driver wheel is stuck. I tried to follow the above instruction, but I can’t go beyond step 10, I can’t take out the cover. Any help will be greatly appreciated,
OldManInChicago - Antwort
do you have place to buy ecovac_deebot_900_54_gear ?? I thinking on printing it but after my printed gear to papper shreder I have no hopes it will last.
Plewu Gracz - Antwort
Thanks for the guide on the Deebot 900 wheel replacement. Though it has partially helps to resolve the problems, but unable to find a wheel replacement. Hope you can help too.
wong CS - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 14
Letzten 7 Tage: 140
Letzten 30 Tage: 589
Insgesamt: 7,436
