Zum Hauptinhalt wechseln
Ecovacs Deebot 900 Wheel Replacement
Was du brauchst
  1. Ecovacs Deebot 900 Wheel Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove all the brushes from the Deebot.
  2. Ecovacs Deebot 900 Wheel Replacement: Schritt 2, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Ecovacs Deebot 900 Wheel Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery cover.
  4. Ecovacs Deebot 900 Wheel Replacement: Schritt 4, Bild 1 von 1
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Ecovacs Deebot 900 Wheel Replacement: Schritt 5, Bild 1 von 1
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
  6. Ecovacs Deebot 900 Wheel Replacement, Front Bumper: Schritt 6, Bild 1 von 2 Ecovacs Deebot 900 Wheel Replacement, Front Bumper: Schritt 6, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  7. Ecovacs Deebot 900 Wheel Replacement: Schritt 7, Bild 1 von 1
    • Remove the black strip on the bottom of the bumper.
  8. Ecovacs Deebot 900 Wheel Replacement: Schritt 8, Bild 1 von 2 Ecovacs Deebot 900 Wheel Replacement: Schritt 8, Bild 2 von 2
    • Carefully lift up the bumper untill it pops out of place.​
  9. Ecovacs Deebot 900 Wheel Replacement: Schritt 9, Bild 1 von 2 Ecovacs Deebot 900 Wheel Replacement: Schritt 9, Bild 2 von 2
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
  10. Ecovacs Deebot 900 Wheel Replacement, Bottom Case: Schritt 10, Bild 1 von 2 Ecovacs Deebot 900 Wheel Replacement, Bottom Case: Schritt 10, Bild 2 von 2
    • Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
  11. Ecovacs Deebot 900 Wheel Replacement: Schritt 11, Bild 1 von 2 Ecovacs Deebot 900 Wheel Replacement: Schritt 11, Bild 2 von 2
    • Insert a Jimmy into the seam and work all the way around the robot.
    • Disconnect the two cables and remove the bottom case from the device.
  12. Ecovacs Deebot 900 Wheel Replacement, Motherboard: Schritt 12, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove the two black screws holding the motherboard in place.​
  13. Ecovacs Deebot 900 Wheel Replacement: Schritt 13, Bild 1 von 1
    • Carefully remove the ribbon cables connected to the top of motherboard.
    • Keep track of where the cables connect to the motherboard.
  14. Ecovacs Deebot 900 Wheel Replacement: Schritt 14, Bild 1 von 1
    • Remove the last three ribbon cables on the underside of the motherboard.​
  15. Ecovacs Deebot 900 Wheel Replacement: Schritt 15, Bild 1 von 1
    • Lift the motherboard out of the Deebot and remove it from the device.
  16. Ecovacs Deebot 900 Wheel Replacement, Wheel: Schritt 16, Bild 1 von 1
    • Using a screwdriver or tweezers, remove the spring by lifting the spring and pulling it off one side.
  17. Ecovacs Deebot 900 Wheel Replacement: Schritt 17, Bild 1 von 2 Ecovacs Deebot 900 Wheel Replacement: Schritt 17, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the four screws holding the wheel assembly in place.
  18. Ecovacs Deebot 900 Wheel Replacement: Schritt 18, Bild 1 von 1
    • Remove the wheel cover.
  19. Ecovacs Deebot 900 Wheel Replacement: Schritt 19, Bild 1 von 3 Ecovacs Deebot 900 Wheel Replacement: Schritt 19, Bild 2 von 3 Ecovacs Deebot 900 Wheel Replacement: Schritt 19, Bild 3 von 3
    • Using the Phillips #00 screwdriver, remove the three screws holding the side brush motor in place and lift the brush motor up.
  20. Ecovacs Deebot 900 Wheel Replacement: Schritt 20, Bild 1 von 2 Ecovacs Deebot 900 Wheel Replacement: Schritt 20, Bild 2 von 2
    • Lift up and remove the wheel assembly and the attached sensor (black cable).
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
6 Kommentare
Thanks, it helps a lot
Agoston David - Antwort
I have an OZMO 930 that the left driver wheel is stuck. I tried to follow the above instruction, but I can’t go beyond step 10, I can’t take out the cover. Any help will be greatly appreciated,
OldManInChicago - Antwort
do you have place to buy ecovac_deebot_900_54_gear ?? I thinking on printing it but after my printed gear to papper shreder I have no hopes it will last.
Plewu Gracz - Antwort
Thanks for the guide on the Deebot 900 wheel replacement. Though it has partially helps to resolve the problems, but unable to find a wheel replacement. Hope you can help too.
wong CS - Antwort
The rubber tires on my Deebot have worn through. Does anybody have a source for rubber tire replacement? The company wants to sell me two entire wheel assemblies. I find that unreasonable.
akobelan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 45
Letzte 7 Tage: 279
Letzte 30 Tage: 1,139
Insgesamt: 38,553
