Zum Hauptinhalt wechseln
Ecovacs Deebot 920 Disassembly
Was du brauchst
  1. Ecovacs Deebot 920 Disassembly, Remove The Bins: Schritt 1, Bild 1 von 2 Ecovacs Deebot 920 Disassembly, Remove The Bins: Schritt 1, Bild 2 von 2
    • Use the thumb tab to remove the water resivoir.
    • Lift the lid and remove the dust bin and cleaning brush.
    • Slide the red power switch off to turn off the unit.
  2. Ecovacs Deebot 920 Disassembly, Remove The Brushes: Schritt 2, Bild 1 von 3 Ecovacs Deebot 920 Disassembly, Remove The Brushes: Schritt 2, Bild 2 von 3 Ecovacs Deebot 920 Disassembly, Remove The Brushes: Schritt 2, Bild 3 von 3
    • Turn the unit over, then locate and remove the side brushes by pulling them straight up.
    • Slide the tabs to remove the beater bar retainer, then slide out the beater bar from its square drive.
  3. Ecovacs Deebot 920 Disassembly, Remove The Skid Plate: Schritt 3, Bild 1 von 3 Ecovacs Deebot 920 Disassembly, Remove The Skid Plate: Schritt 3, Bild 2 von 3 Ecovacs Deebot 920 Disassembly, Remove The Skid Plate: Schritt 3, Bild 3 von 3
    • Remove the 8 black 7mm screws from the skid plate.
    • Lift up the skid plate from one of the corners by the water reservoir and remove.
    • If you have difficulty, you can also try to pry up the plate from the edge by the front bumper.
  4. Ecovacs Deebot 920 Disassembly, Remove The Battery: Schritt 4, Bild 1 von 2 Ecovacs Deebot 920 Disassembly, Remove The Battery: Schritt 4, Bild 2 von 2
    • Remove the 4 black 10mm screws from the weight.
    • Lift the white tabs on the battery to remove it, and unplug it from the motherboard.
  5. Ecovacs Deebot 920 Disassembly, Remove The Bumper Stiffener: Schritt 5, Bild 1 von 2 Ecovacs Deebot 920 Disassembly, Remove The Bumper Stiffener: Schritt 5, Bild 2 von 2
    • Remove the 8 black screws from the front bumper stiffener using a #00 or #0 Phillips screwdriver.
    • Remove 6 black 10mm screws retaining the top cover.
  6. Ecovacs Deebot 920 Disassembly, Remove Additional Screws: Schritt 6, Bild 1 von 2 Ecovacs Deebot 920 Disassembly, Remove Additional Screws: Schritt 6, Bild 2 von 2
    • Flip the unit back over. Use a small flathead screwdriver or spudger to remove the rubber covers near the laser sensor.
    • Remove the two washer head screws.
  7. Ecovacs Deebot 920 Disassembly, Lift The Top Cover: Schritt 7, Bild 1 von 3 Ecovacs Deebot 920 Disassembly, Lift The Top Cover: Schritt 7, Bild 2 von 3 Ecovacs Deebot 920 Disassembly, Lift The Top Cover: Schritt 7, Bild 3 von 3
    • There are 6 clips holding the top cover to the base.
    • Press in at the red arrow, by the water reservoir retention hook, to detach an internal retention clip.
    • The clips are outlined in red in the second image.
    • Pry up on the top cover at the orange arrow to begin unclipping the top of the unit.
    • Two additional clips are at the yellow arrow on either side of the unit. Pressing in at these locations aids in their removal.
  8. Ecovacs Deebot 920 Disassembly, Finish Unclipping Top Cover: Schritt 8, Bild 1 von 2 Ecovacs Deebot 920 Disassembly, Finish Unclipping Top Cover: Schritt 8, Bild 2 von 2
    • The yellow rectangle indicates the location of the side clips in the dust bin area.
    • The final two clips are at the front of the case and should free themselves with a little lifting force and wiggling.
    • There are thin wires connecting sensors on the top of the unit to the motherboard. Do not lift the top up, rather, allow it to fold forward, and rest it against a wall or stack of books.
  9. Ecovacs Deebot 920 Disassembly, Detatch The Top Cover: Schritt 9, Bild 1 von 1
    • Gently unplug the four cables connecting the lid sensors and motors to the motherboard.
    • Using a spudger on the sides of the clips aids greatly in their removal. Try not to pull on the wires, as they are thin and fragile, and could come uncoupled from their connector.
  10. Ecovacs Deebot 920 Disassembly, Remove The Suction Motor: Schritt 10, Bild 1 von 1
    • This section can normally be skipped if performing a different repair.
    • Remove the two silver washer head screws holding down the vacuum assembly with a #1 Phillips driver.
    • Unplug the motor from the motherboard and remove the entire assembly.
  11. Ecovacs Deebot 920 Disassembly, Unscrew And Unplug The Motherboard: Schritt 11, Bild 1 von 3 Ecovacs Deebot 920 Disassembly, Unscrew And Unplug The Motherboard: Schritt 11, Bild 2 von 3 Ecovacs Deebot 920 Disassembly, Unscrew And Unplug The Motherboard: Schritt 11, Bild 3 von 3
    • This step is required to replace the motherboard, side brushes, or beater bar motor. It can be skipped in most other repairs.
    • Remove the 5 silver 7mm screws retaining the motherboard and daughter boards.
    • Fold down the center daughter board and remove the hidden silver 10mm screw. This screw holds in the beater bar housing and can be skipped for other repairs.
    • Remove all of the cables connecting the motherboard to the rest of the unit.
    • There are some connectors underneath the left side of the board, marked in yellow.
    • Depending on your repair, you may not need to remove all or any connectors to access the necessary screws.
  12. Ecovacs Deebot 920 Disassembly, Remove The Water Pump: Schritt 12, Bild 1 von 3 Ecovacs Deebot 920 Disassembly, Remove The Water Pump: Schritt 12, Bild 2 von 3 Ecovacs Deebot 920 Disassembly, Remove The Water Pump: Schritt 12, Bild 3 von 3
    • This section is necessary to repair the water pump, right wheel motor, or beater bar. It can be skipped in most other repairs.
    • Remove the two silver 7mm screws from the side trim panel, and the two silver 7mm screws from the water pump retention clip.
    • Lift out the water pump, being aware of the water lines coming from the side and running underneath it, and place it into the dust bin area (if not replacing).
    • If replacing the water pump, remove the two water hoses from their barb connectors, unplug the motor from the motherboard, and remove.
  13. Ecovacs Deebot 920 Disassembly, Remove The Side Brushes: Schritt 13, Bild 1 von 2 Ecovacs Deebot 920 Disassembly, Remove The Side Brushes: Schritt 13, Bild 2 von 2
    • This step is required to repair the side brushes or beater bar motor. It can be skipped in most other repairs.
    • Remove the two silver 10mm screws holding each side brush motor.
    • It is usually possible to remove these screws without detatching all of the wires from the motherboard, but after unscrewing the motherboard and lifting it gently over its centering pegs.
    • Unplug each motor from the motherboard, if necessary, and remove.
  14. Ecovacs Deebot 920 Disassembly, Remove the wheel wells and springs: Schritt 14, Bild 1 von 2 Ecovacs Deebot 920 Disassembly, Remove the wheel wells and springs: Schritt 14, Bild 2 von 2
    • This section is required to repair the wheel motors or beater bar motor. It can (and should) be skipped in most other repairs.
    • Remove the 4 silver 10mm screws on each wheel well.
    • Many wires are routed around the sides and top of these wheel wells. Take care not to pull or damage these wires when uninstalling the wheel wells.
    • The wheel wells have the traction springs inside of them, so you will hear a snap as you remove the final screws.
    • Do not errantly remove or adjust the black spring retention screw.
  15. Ecovacs Deebot 920 Disassembly, Remove The Beater Housing: Schritt 15, Bild 1 von 1
    • Almost all components, save the suction motor, must be loosened or removed to extract the housing.
    • The beater bar housing is held in by the hidden screw beneath the center daughterboard, as well as one screw from each of the wheel wells.
    • After removing surrounding components, lift up on the motor housing (outlined in blue) and allow it to hinge back towards the dust bin area, pivoting on the 135-degree area.
    • Once the housing for the two internal hinges for the beater bar are free, slide the beater bar housing up and out of the case towards the front.
    • The beater bar housing has a thin rubber dust funnel. Take care not to damage this rubber component.
  16. Ecovacs Deebot 920 Disassembly, Remove The Beater Motor: Schritt 16, Bild 1 von 1
    • Remove the three screws on the side of the beater housing which hold down the motor and its gear case.
    • Push the rubber grommet through the housing towards the motor, and slide the rest of the cable into the housing to free the motor.
Abschluss
To reassemble your device, follow the separate 'reassembly' guide.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Andrej Walilko
1.057 Reputation
4 Anleitungen geschrieben
2 Kommentare
All great information. Except no one will sell internal parts, including motherboard.
Sam Manfredi - Antwort
I was able to find all drive, brush, and suction motors, and the battery, as internal replacement parts on ebay; but if it's a motherboard you're after, an "as is not working" model may be worth a gamble.
Andrej Walilko - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 65
Letzte 30 Tage: 313
Insgesamt: 3,577
