Einleitung
Follow this guide to remove the belt guard on the Edco Cement Saw KL1465H. This procedure is required to remove the belts, as well as the arbor assembly.
Was du brauchst
Disconnect the spark plug to prevent the engine from accidentally starting up during service:
Grab the plastic spark plug cap at the end of the spark plug wire.
Firmly pull to disconnect the spark plug cap from the spark plug.
To prevent the concrete saw from rolling during service, place wheel chocks in front of and behind a rear wheel.
Use a 3/8-inch wrench to remove the two bolts securing the arbor guard.
Remove the arbor guard.
Use a 3/8-inch wrench to remove the two bolts securing the belt guard.
Remove the belt guard.
