Einleitung
Follow this guide to replace a damaged arbor assembly on the Edco Cement Saw KL1465H.
Was du brauchst
Disconnect the spark plug to prevent the engine from accidentally starting up during service:
Grab the plastic spark plug cap at the end of the spark plug wire.
Firmly pull to disconnect the spark plug cap from the spark plug.
To prevent the concrete saw from rolling during service, place wheel chocks in front of and behind a rear wheel.
Use a 3/8-inch wrench to remove the two bolts securing the arbor guard.
Remove the arbor guard.
Use a 3/8-inch wrench to remove the two bolts securing the belt guard.
Remove the belt guard.
Use a 9/16-inch wrench to remove the bolt securing the blade cover.
Use a 3/4-inch wrench to loosen the blade cover pivot bolt, but do not remove it.
Use the included wrenches to remove the jam nut securing the cutting blade to the arbor.
Use a 9/16-inch wrench to remove the four bolts securing the arbor assembly to the concrete saw.
Support the arbor assembly from the bottom and tilt the left side down to remove it from the belts.
Ein Kommentar
I'd really like to see this type of guide done on a machine that has been USED by say rental customers! I do appreciate the guides but they are somewhat unrealistic because everything is new. Also, I didn't see a part number for a whole and assembled arbor. That would be nice to have.
