Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Follow this guide to remove the belt guard on the Edco Cement Saw KL1465H. This procedure is required to remove the belts, as well as the arbor assembly.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
  1. Before you begin, ensure that the machine is powered down and cool to the touch. Disconnect the spark plug to prevent the engine from accidentally starting up during service:
    • Before you begin, ensure that the machine is powered down and cool to the touch.
    • Disconnect the spark plug to prevent the engine from accidentally starting up during service:
    • Grab the plastic spark plug cap at the end of the spark plug wire.
    • Firmly pull to disconnect the spark plug cap from the spark plug.
  2. To prevent the concrete saw from rolling during service, place wheel chocks in front of and behind a rear wheel. To prevent the concrete saw from rolling during service, place wheel chocks in front of and behind a rear wheel. To prevent the concrete saw from rolling during service, place wheel chocks in front of and behind a rear wheel.
    • To prevent the concrete saw from rolling during service, place wheel chocks in front of and behind a rear wheel.
  3. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  4. Use a 3/8-inch wrench to remove the two bolts securing the arbor guard. Remove the arbor guard.
    • Use a 3/8-inch wrench to remove the two bolts securing the arbor guard.
    • Remove the arbor guard.
  5. Use a 3/8-inch wrench to remove the two bolts securing the belt guard. Remove the belt guard. Remove the belt guard.
    • Use a 3/8-inch wrench to remove the two bolts securing the belt guard.
    • Remove the belt guard.
Abschluss
Craig Lloyd
8.810 Reputation
47 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
124 Mitglieder
11.595 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 5
