Zum Hauptinhalt wechseln
Edwin the Duck Motherboard Replacement
Was du brauchst
  1. Edwin the Duck Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 2 Edwin the Duck Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Unscrew the four 9mm screws with a T8 screwdriver bit
    • Remove the back plate off
  2. Edwin the Duck Motherboard Replacement: Schritt 2, Bild 1 von 2 Edwin the Duck Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Carefully take off the rubber skin.
    • Be patient and don't rush. You don't want to rip or damage the rubber skin resulting in losing the waterproof cover.
  3. Edwin the Duck Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Using the J1 screwdriver bit, unscrew all six 9 mm screws that run along the border.
  4. Edwin the Duck Motherboard Replacement: Schritt 4, Bild 1 von 2 Edwin the Duck Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Use the plastic opening tool to open the inside of the duck.
    • Be very careful when splitting the two halves apart. There are wires connecting to both sides. Remember to open slowly.
  5. Edwin the Duck Motherboard Replacement: Schritt 5, Bild 1 von 2 Edwin the Duck Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Using the plastic opening tool pull up the black tab up until it stops.
    • Be careful not to pull up the black tab too far up, otherwise the cable won't be secure anymore.
    • Pull up the white cable tab, up slowly
  6. Edwin the Duck Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Use the J1 screwdriver bit to unscrew all four 9 mm screws attached to the motherboard.
  7. Edwin the Duck Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the top connector as you see in the picture.
    • Replace the new motherboard and you are finished.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Caleb Kim
143 Reputation
1 Anleitung geschrieben
UW Tacoma, Team S1-G4, Rose Fall 2017 Mitglied von UW Tacoma, Team S1-G4, Rose Fall 2017
UWT-ROSE-F17S1G4
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 422
