Zum Hauptinhalt wechseln
Edwin the Duck Rubber Gasket Seal Replacement
Was du brauchst
  1. Edwin the Duck Rubber Gasket Seal Replacement, Rubber Gasket Seal: Schritt 1, Bild 1 von 2 Edwin the Duck Rubber Gasket Seal Replacement, Rubber Gasket Seal: Schritt 1, Bild 2 von 2
    • Unscrew the four 9mm screws with aT8 bit
    • Take the back plate off
  2. Edwin the Duck Rubber Gasket Seal Replacement: Schritt 2, Bild 1 von 2 Edwin the Duck Rubber Gasket Seal Replacement: Schritt 2, Bild 2 von 2
    • Carefully take off the rubber skin.
    • Be patient and don't rush. You don't want to rip or damage the rubber skin otherwise you will lose the waterproof cover.
  3. Edwin the Duck Rubber Gasket Seal Replacement: Schritt 3, Bild 1 von 1
    • Using the J1 bit, unscrew all six 9 mm screws around the border.
  4. Edwin the Duck Rubber Gasket Seal Replacement: Schritt 4, Bild 1 von 2 Edwin the Duck Rubber Gasket Seal Replacement: Schritt 4, Bild 2 von 2
    • Use the plastic opening tool to open the inside of the duck.
    • Be very careful when splitting the two halves apart. There are wires connecting to both sides. So open it very slowly.
  5. Edwin the Duck Rubber Gasket Seal Replacement: Schritt 5, Bild 1 von 2 Edwin the Duck Rubber Gasket Seal Replacement: Schritt 5, Bild 2 von 2
    • Remove the rubber gasket
  6. Edwin the Duck Rubber Gasket Seal Replacement: Schritt 6, Bild 1 von 1
    • Insert your new rubber gasket in and use the plastic opening tool to push the rubber gasket into it's slot
Abschluss
UW Tacoma, Team S1-G4, Rose Fall 2017 Mitglied von UW Tacoma, Team S1-G4, Rose Fall 2017
UWT-ROSE-F17S1G4
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 348
