Zum Hauptinhalt wechseln
Eee Pad Transformer Prime TF201 LED Chip Replacement
Was du brauchst
  1. Eee Pad Transformer Prime TF201 LED Chip Replacement, Opening Your Device: Schritt 1, Bild 1 von 1
    • Power down your device.
    • Place the small suction cup on a corner of the screen and lightly pull up to expose a seam between the screen and case.
  2. Eee Pad Transformer Prime TF201 LED Chip Replacement: Schritt 2, Bild 1 von 3 Eee Pad Transformer Prime TF201 LED Chip Replacement: Schritt 2, Bild 2 von 3 Eee Pad Transformer Prime TF201 LED Chip Replacement: Schritt 2, Bild 3 von 3
    • Insert the plastic opening tool into the seam near the corner of the device.
    • Slowly slide the tool around the perimeter of the device, gradually prying up the screen.
    • It is normal to hear snaps as the spring clips holding the screen in place are released.
    • It is also normal to hear adhesive separating, as a small amount is used to help secure the screen.
  3. Eee Pad Transformer Prime TF201 LED Chip Replacement: Schritt 3, Bild 1 von 3 Eee Pad Transformer Prime TF201 LED Chip Replacement: Schritt 3, Bild 2 von 3 Eee Pad Transformer Prime TF201 LED Chip Replacement: Schritt 3, Bild 3 von 3
    • When the screen is free of all spring clips and adhesive, slowly open the device like a clam shell with the hinge being the left hand side of the device.
    • Do not completely separate the screen from the case by more than a few inches, as they are still connected by three orange ribbon cables.
    • Safely place the device back on the table by laying the screen face down.
    • There will be some slight overlapping of the back of the case over the screen.
  4. Eee Pad Transformer Prime TF201 LED Chip Replacement: Schritt 4, Bild 1 von 2 Eee Pad Transformer Prime TF201 LED Chip Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the ribbon cable by placing a plastic opening tool under the black plastic tab that is on the opposite side of the port as the ribbon cable.
    • Pry upward until the black tab moves 90 degrees, and gently pull the ribbon cable out of the port.
  5. Eee Pad Transformer Prime TF201 LED Chip Replacement: Schritt 5, Bild 1 von 1
    • Place a plastic opening tool under the white plastic tab on one of the ribbon cable ports.
    • Repeat the previous process to remove the other ribbon cable.
  6. Eee Pad Transformer Prime TF201 LED Chip Replacement: Schritt 6, Bild 1 von 1
    • Remove the battery (secured by six screws and a white wire connector) by following the removal portion of this battery replacement guide.
    • The device that we wrote this guide for did not come with a battery, so we cannot include it in our own guide steps.
    • The battery is removed during all repairs to protect against short circuits, shocks, and internal damage to the device.
  7. Eee Pad Transformer Prime TF201 LED Chip Replacement, LED Chip: Schritt 7, Bild 1 von 2 Eee Pad Transformer Prime TF201 LED Chip Replacement, LED Chip: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • With a Phillips #00 screwdriver, remove the one 3.8 mm screw in the LED chip. The LED chip is a small green chip (about 1 square centimeter) located at the top center of the device.
    • Gently remove the chip with a pair of precision tweezers by grabbing the chip from one side, being careful not to pinch on a black piece of hardware on the chip.
Abschluss
Aaron Morland
346 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 10-1, Livingston Fall 2016 Mitglied von Cal Poly, Team 10-1, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G1
2 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 341
