Einleitung
This guide will show you how to replace a broken or cracked screen on your tablet.
Was du brauchst
Power down your device.
Place the small suction cup on a corner of the screen and lightly pull up to expose a seam between the screen and case.
Insert the plastic opening tool into the seam near the corner of the device.
Slowly slide the tool around the perimeter of the device, gradually prying up the screen.
When the screen is free of all spring clips and adhesive, slowly open the device like a clam shell with the hinge being the left hand side of the device.
Safely place the device back on the table by laying the screen face down.
Disconnect the ribbon cable by placing a plastic opening tool under the black plastic tab that is on the opposite side of the port as the ribbon cable.
Pry upward until the black tab moves 90 degrees, and gently pull the ribbon cable out of the port.
Place a plastic opening tool under the white plastic tab on one of the ribbon cable ports.
Repeat the previous process to remove the other ribbon cable.
Remove the battery (secured by six screws and a white wire connector) by following the removal portion of this battery replacement guide.
Place the iOpeners on the edges of the tablet and let sit for 2-5 minutes
Remove the iOpeners and repeat on the other side of the tablet
Slowly pry open the tablet using the plastic opening tool.
Place small suction cup on the screen and pull apart slowly to separate screen
To reassemble your device, apply glue to the screen and press it to the LCD, then follow these instructions in reverse order.
