Zum Hauptinhalt wechseln
Eightarc Fusion Headphone Jack Replacement
Was du brauchst
  1. Eightarc Fusion Headphone Jack Replacement, Headphone Jack: Schritt 1, Bild 1 von 2 Eightarc Fusion Headphone Jack Replacement, Headphone Jack: Schritt 1, Bild 2 von 2
    • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface or prop the controller up to avoid stress on the joystick.
    • Place the controller face down (buttons and joystick down).
    • Use a Phillips Head #1 screwdriver to remove the eight 9.65mm screws located on the felt and metal backplate.
    • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
    Frag FixBot
    Kommentar hinzufügen
  2. Eightarc Fusion Headphone Jack Replacement: Schritt 2, Bild 1 von 1
    • Open the door for the cord storage compartment on the right side of the device.
    • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
    Frag FixBot
  3. Eightarc Fusion Headphone Jack Replacement: Schritt 3, Bild 1 von 2 Eightarc Fusion Headphone Jack Replacement: Schritt 3, Bild 2 von 2
    • Grasp the white plug connecting the wires to the headphone jack, and pull gently upwards.
    Frag FixBot
  4. Eightarc Fusion Headphone Jack Replacement: Schritt 4, Bild 1 von 1
    • Using a Phillips head #1 screwdriver, remove the two washer head screws from the headphone jack.
    Frag FixBot
  5. Eightarc Fusion Headphone Jack Replacement: Schritt 5, Bild 1 von 2 Eightarc Fusion Headphone Jack Replacement: Schritt 5, Bild 2 von 2
    • Gently wiggle the headphone jack left and right, pulling it towards you until it slides out of the hole in the enclosure.
    Frag FixBot
Abschluss
Cal Poly, Team 17-35, Amido Winter 2015 Mitglied von Cal Poly, Team 17-35, Amido Winter 2015
CPSU-AMIDO-W15S17G35
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 10
Letzte 30 Tage: 42
Insgesamt: 627
