Einleitung
This guide demonstrates the removal of the headphone jack from the Eightarc Fusion.
Warning: Use caution when placing the joystick face down on the table. The joystick can crack if placed down too hard. Be sure to gently turn the device over and place it face down. It can be helpful to balance the other side of the device to distribute the weight.
Was du brauchst
Place the controller face down (buttons and joystick down).
Use a Phillips Head #1 screwdriver to remove the eight 9.65mm screws located on the felt and metal backplate.
Open the door for the cord storage compartment on the right side of the device.
Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
Grasp the white plug connecting the wires to the headphone jack, and pull gently upwards.
Using a Phillips head #1 screwdriver, remove the two washer head screws from the headphone jack.
Gently wiggle the headphone jack left and right, pulling it towards you until it slides out of the hole in the enclosure.
