Einleitung
This guide will show you how to dissemble your jet fan and replace a broken fan blade.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Tools needed to fix your Ryobi Electronic Jet Fan Blower: ½” wrench or socket and a #16 5 point star screwdriver
Locate the 7 screws along the handle and remove them with the #16 5 point star screwdriver
Locate the 2 additional screws on the under-body and remove them
Gently wedge apart the handle being careful not to damage the wiring inside.
Carefully separate the two parts of the handle
Remove the grey switch plate. Note how the wiring is laid out on your particular model as it may vary.
Remove the 2 screws and spacer holding the plug in.
Gently wedge the chute away from the main carriage. It may be on tight but should come apart with light pressure.
Remove nut with a ½” wrench (or socket) clockwise while holding the fan blade still.
The fan blade should easily slide off once the nut is removed. If you are looking to replace your fan blade, you are now able to slide one on.
