Zum Hauptinhalt wechseln
Electric Stove Burners and Drip Pans Replacement
Was du brauchst
  1. Electric Stove Burners and Drip Pans Replacement, Burners and Drip Pans: Schritt 1, Bild 1 von 1
    • Unplug the stove or turn off the breaker, if your stove does not allow you to unplug it.
  2. Electric Stove Burners and Drip Pans Replacement: Schritt 2, Bild 1 von 3 Electric Stove Burners and Drip Pans Replacement: Schritt 2, Bild 2 von 3 Electric Stove Burners and Drip Pans Replacement: Schritt 2, Bild 3 von 3
    • Slide the burners out of the receptacle block.
    • The prongs attached to the burner in the second image fit the slots in the receptacle block in the third image.
  3. Electric Stove Burners and Drip Pans Replacement: Schritt 3, Bild 1 von 1
    • Lift the drip pan out of the stove.
  4. Electric Stove Burners and Drip Pans Replacement: Schritt 4, Bild 1 von 2 Electric Stove Burners and Drip Pans Replacement: Schritt 4, Bild 2 von 2
    • Wipe the surface underneath the drip pan to clean it and ensure there are no food remnants
  5. Electric Stove Burners and Drip Pans Replacement: Schritt 5, Bild 1 von 2 Electric Stove Burners and Drip Pans Replacement: Schritt 5, Bild 2 von 2
    • If all the wires look satisfactory, add the new drip pan.
    • Ensure you have the burner with the open ring so the prongs reach the receptacle block.
  6. Electric Stove Burners and Drip Pans Replacement: Schritt 6, Bild 1 von 1
    • Slide new burner through the receptacle.
    • Reassemble stove after.
Ziellinie
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 27
Letzte 30 Tage: 107
Insgesamt: 4,142
