Zum Hauptinhalt wechseln
Electric Wheelchair Battery Replacement
  1. Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: Schritt 1, Bild 1 von 3 Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: Schritt 1, Bild 2 von 3 Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: Schritt 1, Bild 3 von 3
    • Locate the two batteries under the back of the wheelchair.
    • Pull the first battery pack to where you can reach the red battery connector.
    • Be careful, the batteries are heavy.
  2. Electric Wheelchair Battery Replacement: Schritt 2, Bild 1 von 2 Electric Wheelchair Battery Replacement: Schritt 2, Bild 2 von 2
    • Disconnect the red battery connectors by pulling them apart.
  3. Electric Wheelchair Battery Replacement: Schritt 3, Bild 1 von 2 Electric Wheelchair Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove the first and second battery from the wheelchair.
  4. Electric Wheelchair Battery Replacement: Schritt 4, Bild 1 von 2 Electric Wheelchair Battery Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the black battery connectors by pulling them apart.
  5. Electric Wheelchair Battery Replacement: Schritt 5, Bild 1 von 3 Electric Wheelchair Battery Replacement: Schritt 5, Bild 2 von 3 Electric Wheelchair Battery Replacement: Schritt 5, Bild 3 von 3
    • One at a time, disconnect the clips holding each battery case closed.
    • Open each case to reveal the battery inside.
  6. Electric Wheelchair Battery Replacement: Schritt 6, Bild 1 von 3 Electric Wheelchair Battery Replacement: Schritt 6, Bild 2 von 3 Electric Wheelchair Battery Replacement: Schritt 6, Bild 3 von 3
    • Remove the old battery from each case.
    • Put one new battery into each plastic case the old batteries were removed from.
  7. Electric Wheelchair Battery Replacement: Schritt 7, Bild 1 von 1
    • Reattach the clips on each of the battery's protective casings.
  8. Electric Wheelchair Battery Replacement: Schritt 8, Bild 1 von 3 Electric Wheelchair Battery Replacement: Schritt 8, Bild 2 von 3 Electric Wheelchair Battery Replacement: Schritt 8, Bild 3 von 3
    • Place the first battery back into the holder under the wheelchair.
    • Make sure that it is pushed all the way to the front of the wheelchair.
    • Place the second battery back into the holder.
  9. Electric Wheelchair Battery Replacement: Schritt 9, Bild 1 von 3 Electric Wheelchair Battery Replacement: Schritt 9, Bild 2 von 3 Electric Wheelchair Battery Replacement: Schritt 9, Bild 3 von 3
    • Reconnect the black battery connectors.
    • Do not connect the red connectors until the black are connected.
    • Reconnect the red battery connectors.
    • Check that the chair turns on and is fully charged.
Ziellinie
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Oakland University, Team 6-1, Walwema Winter 2016 Mitglied von Oakland University, Team 6-1, Walwema Winter 2016
OAK-WALWEMA-W16S6G1
10 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
I greatly enjoyed reading your article :) Please continue publishing helpful topics like this. Regards, from <a href="http://www.scootersnchairs.com">Scooters 'N Chairs</a>.
Justin Lubomirsky - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 22
Letzte 30 Tage: 77
Insgesamt: 6,856
