Einleitung
Broken outlets are a very common problem in many households and can be fixed in a few short steps. Outlets are used by everyone in all households for common every day things such as cooking, getting ready, and cleaning. Broken outlets can create hazards in homes due to exposing electrical wires that can cause fires. (Staff, 2011)
Was du brauchst
Remove screws from outlet that are connected to the wall using a Phillips screwdriver.
Connect wires to new outlet being sure to connected them to their designated port. They are labeled on the back of the outlet with: neutral, ground and hot.
Insert wire into the designated port and tighten with Phillips Screwdriver.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
