Zum Hauptinhalt wechseln
Electrohome EAAC475 Button Replacement
Was du brauchst
  1. Electrohome EAAC475 Button Replacement, Battery: Schritt 1, Bild 1 von 2 Electrohome EAAC475 Button Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 Button Replacement: Schritt 2, Bild 1 von 1
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 Button Replacement, Buttons: Schritt 3, Bild 1 von 2 Electrohome EAAC475 Button Replacement, Buttons: Schritt 3, Bild 2 von 2
    • Disconnect the radio from all power sources.
    • Remove the two 10 mm Phillips #1 screws from the bottom of the device.
    • Remove two 10 mm Phillips #1 screws from the back side of the device.
  4. Electrohome EAAC475 Button Replacement: Schritt 4, Bild 1 von 3 Electrohome EAAC475 Button Replacement: Schritt 4, Bild 2 von 3 Electrohome EAAC475 Button Replacement: Schritt 4, Bild 3 von 3
    • Carefully and slowly pull the lower case away from the rest of the device.
    • Do not completely separate the lower case. There are several wires connecting the two halves of the device.
    • Flip the device over to access the button assembly.
    • Slowly remove the button contact board from the assembly.
  5. Electrohome EAAC475 Button Replacement: Schritt 5, Bild 1 von 2 Electrohome EAAC475 Button Replacement: Schritt 5, Bild 2 von 2
    • Remove the two 7 mm Phillips # 1 screws holding the buttons.
    • Remove the plastic buttons.
Abschluss
Sohail Khatri
201 Reputation
2 Anleitungen geschrieben
IUPUI, Team 2-1, Harley Spring 2016 Mitglied von IUPUI, Team 2-1, Harley Spring 2016
IUPUI-HARLEY-S16S2G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 247
