Einleitung
Sometimes the focus lens can go bad or detaches from its holder. This guide will help you how to put it back in place or replace with a new one so that your electrohome EAAC475 works properly.
Was du brauchst
Remove the 10 mm Phillips #1 screw from the battery cover.
Remove the battery cover.
Slowly and carefully move one side away from another without detaching anything on the device.
Using a metal spudger, pry into the crease until it separates enough to slip the spudger between the pieces.
Slide the tool along the crease to separate.
