Einleitung
This simple five-step guide will show you how to replace your Element GC-1020's display.
Was du brauchst
Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
Carefully pull the back of the device (the silver portion) apart from the rest of the device.
Unscrew the visible Philips head screws (size: 3.968 mm) on the motherboard located on the top of left and right sides. Use a PH #0 sized screw driver head for removal.
The display is attached to a dark yellow, flimsy, plastic material. This material is then attached to the motherboard. Tear off the plastic, successfully detaching the motherboard and display from each other.
Once the display is by itself, separate from the rest of the device, you are ready to put in your new display.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
but can i ask do you know how to reboot the software ?
i mean we try to put in our music or video or image inside. can it be done
