Einleitung
Use this guide to access the headphone jack and check soldered connections. If you are planning to follow this replacement guide, you should have identified the headphone jack as a source of a problem (or maybe you just want to see the guts of your Element GC-1020).
Was du brauchst
Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
Carefully pull the back of the device (the silver portion) apart from the rest of the device.
Desolder the four points where it is soldered to the motherboard.
When completed pull the headphone jack off using tweezers and replace.
Eine weitere Person hat diese Anleitung absolviert.
