Einleitung
This guide will help you replace the internal speakers for your Ematic eGlide 4 and where to locate the speaker connection. The speakers are connected to the rear panel using a mild adhesive that does not need special care. The speakers are also connected to the motherboard via soldered wire connections, which must be desoldered in order to replace the speakers.
Was du brauchst
Carefully remove the speakers from the rear panel.
Pull the speakers off of the rear panel.
