Zum Hauptinhalt wechseln
Ematic FunTab 2 Motherboard Replacement
Was du brauchst
  1. Ematic FunTab 2 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Remove back of Ematic FunTab by using the plastic opening tool to pry the back open.
  2. Ematic FunTab 2 Motherboard Replacement: Schritt 2, Bild 1 von 3 Ematic FunTab 2 Motherboard Replacement: Schritt 2, Bild 2 von 3 Ematic FunTab 2 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Next, you need to remove all connections to the motherboard and the device.
    • Start by first removing the tape from all the connections.
    • Be careful not to remove the camera.
  3. Ematic FunTab 2 Motherboard Replacement: Schritt 3, Bild 1 von 3 Ematic FunTab 2 Motherboard Replacement: Schritt 3, Bild 2 von 3 Ematic FunTab 2 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Remove LCD connector from the LCD.
    • Be sure to flip up the retaining tabs before pulling the LCD connector out. (It is the black tab on the connection port).
  4. Ematic FunTab 2 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove camera connection from camera with tweezers.
    • Again, be sure to flip up the retaining tab before pulling the connector.
  5. Ematic FunTab 2 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Remove speaker connection from speaker with tweezers.
    • Before pulling the speaker connection make sure the retaining tab is flipped up.
  6. Ematic FunTab 2 Motherboard Replacement: Schritt 6, Bild 1 von 3 Ematic FunTab 2 Motherboard Replacement: Schritt 6, Bild 2 von 3 Ematic FunTab 2 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Remove wires:
    • Start by removing the black wire on each side.
    • Next, remove the WiFi antenna wire from the motherboard.
    • Finally, remove the yellow, red, and black wires.
    • To put the wires back in their correct locations you will need a soldering iron to solder the wire back in place. You will do this once the motherboard is replaced. Here is a guide on how to solder Wie man Lötverbindungen herstellt und entlötet
  7. Ematic FunTab 2 Motherboard Replacement: Schritt 7, Bild 1 von 3 Ematic FunTab 2 Motherboard Replacement: Schritt 7, Bild 2 von 3 Ematic FunTab 2 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Unscrew all four screws on motherboard with the Phillip's head screwdriver.
    • All of the screws are the same size, and should all fit in either corresponding screw location.
  8. Ematic FunTab 2 Motherboard Replacement: Schritt 8, Bild 1 von 2 Ematic FunTab 2 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • It is now safe to remove and replace the old motherboard with your new motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
University of Alabama, Team 1-1, Naidoo Spring 2015 Mitglied von University of Alabama, Team 1-1, Naidoo Spring 2015
UA-NAIDOO-S15S1G1
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 1,093
