Zum Hauptinhalt wechseln
Ematic FunTab 3 Camera Replacement
Was du brauchst
  1. Ematic FunTab 3 Camera Replacement, Back Panel: Schritt 1, Bild 1 von 3 Ematic FunTab 3 Camera Replacement, Back Panel: Schritt 1, Bild 2 von 3 Ematic FunTab 3 Camera Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Camera Replacement: Schritt 2, Bild 1 von 1
    • Pull the back panel away from the screen.
  3. Ematic FunTab 3 Camera Replacement, Camera: Schritt 3, Bild 1 von 2 Ematic FunTab 3 Camera Replacement, Camera: Schritt 3, Bild 2 von 2
    • Remove the black tape to reveal the wire ribbon connector.
  4. Ematic FunTab 3 Camera Replacement: Schritt 4, Bild 1 von 1
    • Use the plastic opening tool to flip up the black retaining tab.
  5. Ematic FunTab 3 Camera Replacement: Schritt 5, Bild 1 von 2 Ematic FunTab 3 Camera Replacement: Schritt 5, Bild 2 von 2
    • Pull out the wire ribbon connected to the camera.
    • The camera is held in place by glue, so extra force may be required.
    • Remove the camera from the device.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
Abschluss
Amanda Davis
581 Reputation
5 Anleitungen geschrieben
UW Tacoma, Team S1-G5, Cardinal Summer 2018 Mitglied von UW Tacoma, Team S1-G5, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G5
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 178
