Zum Hauptinhalt wechseln
Ematic FunTab 3 Touch Screen Replacement
Was du brauchst
  1. Ematic FunTab 3 Touch Screen Replacement, Back Panel: Schritt 1, Bild 1 von 3 Ematic FunTab 3 Touch Screen Replacement, Back Panel: Schritt 1, Bild 2 von 3 Ematic FunTab 3 Touch Screen Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
    Frag FixBot
  2. Ematic FunTab 3 Touch Screen Replacement: Schritt 2, Bild 1 von 1
    • Pull the back panel away from the screen.
    Frag FixBot
  3. Ematic FunTab 3 Touch Screen Replacement, Motherboard: Schritt 3, Bild 1 von 1
    • Remove the black tape to reveal the screen connector.
    Frag FixBot
  4. Ematic FunTab 3 Touch Screen Replacement: Schritt 4, Bild 1 von 2 Ematic FunTab 3 Touch Screen Replacement: Schritt 4, Bild 2 von 2
    • Flip up the retaining tab using the plastic opening tool.
    • Pull out the screen wire ribbon to disconnect the screen and motherboard.
    Frag FixBot
  5. Ematic FunTab 3 Touch Screen Replacement: Schritt 5, Bild 1 von 2 Ematic FunTab 3 Touch Screen Replacement: Schritt 5, Bild 2 von 2
    • Using a PH 00 screwdriver, remove the four 4.5 mm screws that are holding the motherboard in place.
    Frag FixBot
  6. Ematic FunTab 3 Touch Screen Replacement: Schritt 6, Bild 1 von 1
    • It is now safe to remove and replace the old motherboard with your new motherboard.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
    Frag FixBot
  7. Ematic FunTab 3 Touch Screen Replacement, Touch Screen: Schritt 7, Bild 1 von 2 Ematic FunTab 3 Touch Screen Replacement, Touch Screen: Schritt 7, Bild 2 von 2
    • Insert the hook side of the opening tool between the case and display.
    • Press down on the tool until the screen is clear of the white retaining tabs.
    • Use the plastic opening tool to gently pry up the screen.
    • This is best done on the corner closest to the wire ribbon.
    • Continue prying around the screen until the screen pops out.
    Frag FixBot
  8. Ematic FunTab 3 Touch Screen Replacement: Schritt 8, Bild 1 von 1
    • After the screen has come lose, remove it from the device.
    • When reassembling, make sure the screen locks in place, this may require extra pressure
    Frag FixBot
Abschluss
UW Tacoma, Team S1-G5, Cardinal Summer 2018 Mitglied von UW Tacoma, Team S1-G5, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G5
4 Mitglieder
12 Anleitungen geschrieben
1 Kommentar zur Anleitung
Where can I get a new display for my emoticons funtab 3?
DanTheMan RBLX - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 56
Insgesamt: 1,189
