Zum Hauptinhalt wechseln
Ematic Genesis 2 Audio Jack Repair
Was du brauchst
  1. Ematic Genesis 2 Audio Jack Repair, Ematic Genesis 2 Audio Jack Repair: Schritt 1, Bild 1 von 2 Ematic Genesis 2 Audio Jack Repair, Ematic Genesis 2 Audio Jack Repair: Schritt 1, Bild 2 von 2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Audio Jack Repair: Schritt 2, Bild 1 von 3 Ematic Genesis 2 Audio Jack Repair: Schritt 2, Bild 2 von 3 Ematic Genesis 2 Audio Jack Repair: Schritt 2, Bild 3 von 3
    • Remove all four screws surrounding the battery with the screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Audio Jack Repair: Schritt 3, Bild 1 von 1
    • Remove the two screws that hold the audio jack in place. Carefully lift the audio jack out of the compartment.
    • Use compressed air or a Q-tip to gently clear out the dirt from the inside of the audio jack. This will help make sure future connections are clear.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 151
