Zum Hauptinhalt wechseln
Ematic Genesis 2 Battery Replacement
Was du brauchst
  1. Ematic Genesis 2 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Ematic Genesis 2 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Battery Replacement: Schritt 2, Bild 1 von 3 Ematic Genesis 2 Battery Replacement: Schritt 2, Bild 2 von 3 Ematic Genesis 2 Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove all four screws surrounding the battery with a Phillips Head Screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Battery Replacement: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Desoldering Pump
    $3.99
    Kaufen
    • Carefully remove the solder that connects the battery wires to the device using the solder sucker tool and a soldering iron.
    • When using the soldering iron to heat the existing solder, do not damage the device or surrounding connections.
    • Once all solder is gone, remove the wires from the device to free the battery.
  4. Ematic Genesis 2 Battery Replacement: Schritt 4, Bild 1 von 1
    • Use the soldering iron to solder the wires from the new battery to the device.
    • The connections from the wires should go in order from left to right being white, black (negative), and red (positive), respectively.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Brandon Key
246 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 344
