Einleitung
This repair guide will teach you how to replace the battery in the Ematic Genesis 2 tablet.
Was du brauchst
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
Remove all four screws surrounding the battery with a Phillips Head Screwdriver.
Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
In diesem Schritt verwendetes Werkzeug:Desoldering Pump$3.99
Carefully remove the solder that connects the battery wires to the device using the solder sucker tool and a soldering iron.
Once all solder is gone, remove the wires from the device to free the battery.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
