Zum Hauptinhalt wechseln
Ematic Genesis 2 Screen Replacement
Was du brauchst
  1. Ematic Genesis 2 Screen Replacement, Screen: Schritt 1, Bild 1 von 2 Ematic Genesis 2 Screen Replacement, Screen: Schritt 1, Bild 2 von 2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Screen Replacement: Schritt 2, Bild 1 von 3 Ematic Genesis 2 Screen Replacement: Schritt 2, Bild 2 von 3 Ematic Genesis 2 Screen Replacement: Schritt 2, Bild 3 von 3
    • Remove all four screws surrounding the battery with a Phillips Head Screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Screen Replacement: Schritt 3, Bild 1 von 2 Ematic Genesis 2 Screen Replacement: Schritt 3, Bild 2 von 2
    • Remove the three screws surrounding the circuit board using the Phillips Head Screwdriver.
    • Remove the circuit board from the device by uncliping the copper flexible PCB ribbon cable from the circuit board.
  4. Ematic Genesis 2 Screen Replacement: Schritt 4, Bild 1 von 1
    • Use the Small Pointed Metal Spudger to separate the LED screen from the front screen by gently wedging the spudger between the screen and the device.
  5. Ematic Genesis 2 Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove the glass from the front casing by using the metal spudger to break it free from the device. (It's held together by glue.)
    • Install the new screen.
Abschluss
Brandon Key
246 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 439
