Zum Hauptinhalt wechseln
Ematic Genesis Camera Replacement
Was du brauchst
  1. Ematic Genesis Camera Replacement, Ematic Genesis Casing: Schritt 1, Bild 1 von 3 Ematic Genesis Camera Replacement, Ematic Genesis Casing: Schritt 1, Bild 2 von 3 Ematic Genesis Camera Replacement, Ematic Genesis Casing: Schritt 1, Bild 3 von 3
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
  2. Ematic Genesis Camera Replacement: Schritt 2, Bild 1 von 3 Ematic Genesis Camera Replacement: Schritt 2, Bild 2 von 3 Ematic Genesis Camera Replacement: Schritt 2, Bild 3 von 3
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
  3. Ematic Genesis Camera Replacement: Schritt 3, Bild 1 von 1
    • Remove back plate from screen plate and lay both down flat next to each other.
  4. Ematic Genesis Camera Replacement, Camera: Schritt 4, Bild 1 von 2 Ematic Genesis Camera Replacement, Camera: Schritt 4, Bild 2 von 2
    • Once the panels are separated, remove the tape holding down the ribbon connector that is connecting the camera to the motherboard.
  5. Ematic Genesis Camera Replacement: Schritt 5, Bild 1 von 2 Ematic Genesis Camera Replacement: Schritt 5, Bild 2 von 2
    • Lift up the black lever of the connector that holds the camera ribbon in place.
  6. Ematic Genesis Camera Replacement: Schritt 6, Bild 1 von 2 Ematic Genesis Camera Replacement: Schritt 6, Bild 2 von 2
    • Gently pull the ribbon out of the connector and lift the camera out of the casing.
    • There is adhesive holding the camera in the case. Pull up strong enough to separate the camera from the casing without damaging the components.
Abschluss
Baylor, Team 4-3, Williams Spring 2015 Mitglied von Baylor, Team 4-3, Williams Spring 2015
BU-WILLIAMS-S15S4G3
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 171
