Zum Hauptinhalt wechseln
Ematic Genesis Speaker Replacement
Was du brauchst
  1. Ematic Genesis Speaker Replacement, Ematic Genesis Casing: Schritt 1, Bild 1 von 3 Ematic Genesis Speaker Replacement, Ematic Genesis Casing: Schritt 1, Bild 2 von 3 Ematic Genesis Speaker Replacement, Ematic Genesis Casing: Schritt 1, Bild 3 von 3
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
  2. Ematic Genesis Speaker Replacement: Schritt 2, Bild 1 von 3 Ematic Genesis Speaker Replacement: Schritt 2, Bild 2 von 3 Ematic Genesis Speaker Replacement: Schritt 2, Bild 3 von 3
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
  3. Ematic Genesis Speaker Replacement: Schritt 3, Bild 1 von 1
    • Remove back plate from screen plate and lay both down flat next to each other.
  4. Ematic Genesis Speaker Replacement, Speaker: Schritt 4, Bild 1 von 1
    • Once panels are separated, disconnect speaker wires from motherboard.
    • Make sure device is completely turned off before doing this to avoid a potential electric shock.
  5. Ematic Genesis Speaker Replacement: Schritt 5, Bild 1 von 2 Ematic Genesis Speaker Replacement: Schritt 5, Bild 2 von 2
    • Insert the flat end of the spudger between the casing and the speaker. Push inwards to pry the speaker from the casing.
Abschluss
Baylor, Team 4-3, Williams Spring 2015 Mitglied von Baylor, Team 4-3, Williams Spring 2015
BU-WILLIAMS-S15S4G3
3 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
This help us alot, thanks for posting troubleshooting
wikirichard - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 192
