Zum Hauptinhalt wechseln
Ematic Model FTABMP2 Battery Replacement
Was du brauchst
  1. Ematic Model FTABMP2 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Ematic Model FTABMP2 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use a spudger to pry open the case. Do this on the long side of the case. This will reveal the inside.
  2. Ematic Model FTABMP2 Battery Replacement: Schritt 2, Bild 1 von 2 Ematic Model FTABMP2 Battery Replacement: Schritt 2, Bild 2 von 2
    • Disconnect the LCD cable from the motherboard by pressing together the two sides of the clamp to separate the device into two.
  3. Ematic Model FTABMP2 Battery Replacement: Schritt 3, Bild 1 von 2 Ematic Model FTABMP2 Battery Replacement: Schritt 3, Bild 2 von 2
    • First, Remove the screws holding down the motherboard. Then remove the plastic power and volume buttons.
    • Next, remove the two side grips of the device. Now, you can remove the motherboard, speaker, and battery as one from the device.
  4. Ematic Model FTABMP2 Battery Replacement: Schritt 4, Bild 1 von 1
    • Unsolder the gray, black, and red wires from the motherboard to release the battery.
Abschluss
Timothy
505 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 9-2, Brown Winter 2015 Mitglied von USF Tampa, Team 9-2, Brown Winter 2015
USFT-BROWN-W15S9G2
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 189
