Einleitung
In this guide you will be learning how to fix the Ematic model FTABMP2 camera in three easy steps. A warning though is when taking the Ematic apart use care with parts as well as unplugging components from the motherboard also make sure you discharge yourself from static by touching metal to prevent damage to electrical components.
Was du brauchst
Use the opening tool to carefully pry open the case to reveal the motherboard underneath.
Flip open the retaining flap on the LCD cable.
Remove the LCD from the rest of the tablet.
