Zum Hauptinhalt wechseln
Ematic Model FTABMP2 Case Replacement
Was du brauchst
  1. Ematic Model FTABMP2 Case Replacement, Case: Schritt 1, Bild 1 von 2 Ematic Model FTABMP2 Case Replacement, Case: Schritt 1, Bild 2 von 2
    • Use a spudger to pry open the case of your device to reveal the inside.
  2. Ematic Model FTABMP2 Case Replacement: Schritt 2, Bild 1 von 2 Ematic Model FTABMP2 Case Replacement: Schritt 2, Bild 2 von 2
    • Disconnect the LCD cable from the motherboard by pressing together the two sides of the clamp to separate the device into two.
  3. Ematic Model FTABMP2 Case Replacement: Schritt 3, Bild 1 von 1
    • Use the spudger to pry the LCD from the clamps holding it to the case.
  4. Ematic Model FTABMP2 Case Replacement: Schritt 4, Bild 1 von 2 Ematic Model FTABMP2 Case Replacement: Schritt 4, Bild 2 von 2
    • If you need to remove the back part of the casing, after disconnecting the LCD display from the motherboard, remove the screws holding down the motherboard. Remove the plastic power and volume buttons. remove the two side grips of the device.
  5. Ematic Model FTABMP2 Case Replacement: Schritt 5, Bild 1 von 2 Ematic Model FTABMP2 Case Replacement: Schritt 5, Bild 2 von 2
    • Remove the motherboard, speaker, and battery as a whole, which leaves just the back casing of the device.
Abschluss
Timothy
505 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 9-2, Brown Winter 2015 Mitglied von USF Tampa, Team 9-2, Brown Winter 2015
USFT-BROWN-W15S9G2
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 168
