Zum Hauptinhalt wechseln
Emson Star Wars R2-D2 Humidifier Fan Replacement
Was du brauchst
  1. Emson Star Wars R2-D2 Humidifier Fan Replacement, Fan: Schritt 1, Bild 1 von 1
    • Remove the top cover of the humidifier by pulling upwards.
  2. Emson Star Wars R2-D2 Humidifier Fan Replacement: Schritt 2, Bild 1 von 1
    • Grip the dial from the front of the device and gently pull it away to remove it.
  3. Emson Star Wars R2-D2 Humidifier Fan Replacement: Schritt 3, Bild 1 von 1
    • Remove the blue water tank of the humidifier by pulling upwards.
  4. Emson Star Wars R2-D2 Humidifier Fan Replacement: Schritt 4, Bild 1 von 2 Emson Star Wars R2-D2 Humidifier Fan Replacement: Schritt 4, Bild 2 von 2
    • Use a PH1 screwdriver bit and 150mm extension to unscrew the four screws from the bottom cover.
  5. Emson Star Wars R2-D2 Humidifier Fan Replacement: Schritt 5, Bild 1 von 1
    • Remove the blue plastic top by pulling upwards on the middle notch.
  6. Emson Star Wars R2-D2 Humidifier Fan Replacement: Schritt 6, Bild 1 von 1
    • This is where the fan is located. Carefully remove the fan from its compartment.
    • At this stage, you may remove the pin connector of the fan from the printed circuit board. However, it may be difficult to pull the pin. We recommend removing the printed circuit board for more clearance during removal.
    • Remove the screws on the printed circuit board using the same PH1 driver.
  7. Emson Star Wars R2-D2 Humidifier Fan Replacement: Schritt 7, Bild 1 von 2 Emson Star Wars R2-D2 Humidifier Fan Replacement: Schritt 7, Bild 2 von 2
    • Grip the fan's connector located on the printed circuit board and pull it away from the connector (see second picture).
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Yash Chari
240 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 8-5, Eyestone Spring 2017 Mitglied von USF Tampa, Team 8-5, Eyestone Spring 2017
USFT-EYESTONE-S17S8G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 762
