Einleitung
Replacing the battery in the Enabot EBO SE can be essential in prolonging the lifespan on this product. Overcharging or a faulty battery can drastically impact the ability of the Enabot EBO SE to function. Replacing the battery when damaged or worn down can revitalize your robot pal and help prevent unnecessary e-waste. In these following steps we will show you how to replace your battery.
Was du brauchst
Gently turn the robot upside down.
Place the robot on a stable surface to prevent it from rolling or falling.
Pull the wheel assembly towards you so it comes straight off without resistance.
Use a Torx screwdriver to remove the four 9 mm screws from the assembly.
Use your fingernail to carefully press down and eject the Micro SD Card from the back of the Enabot.
Using the iFixit opening tool or your fingernail, place it underneath the gray tab on the lower housing.
Lift the tab up and pull out the ribbon cable to disconnect it from the lower housing.
Gently use your finger nails to lift up and disconnect both wires to fully separate the upper and lower housings.
Use the iFixit opening tool or your fingernail to disconnect the cable by placing the edge underneath the gray tab.
Flip the tab up and pull the ribbon cable out.
Disconnect the red and blue wires from the daughterboard by using your finger nails to pull up on the connector to disconnect.
Use a Phillips #00 screwdriver to remove both 7.4 mm screws from the side of the battery's casing.
Pull the battery casing upwards from the lower half of the assembly to remove it.
Eine weitere Person hat diese Anleitung absolviert.
