Zum Hauptinhalt wechseln
Enabot EBO SE Camera Replacement
Was du brauchst
  1. Enabot EBO SE Camera Replacement, Wheel Assembly: Schritt 1, Bild 1 von 1
    • Gently turn the robot upside down.
    • Place the robot on a stable surface to prevent it from rolling or falling.
  2. Enabot EBO SE Camera Replacement: Schritt 2, Bild 1 von 3 Enabot EBO SE Camera Replacement: Schritt 2, Bild 2 von 3 Enabot EBO SE Camera Replacement: Schritt 2, Bild 3 von 3
    • Use a flathead 2.5 mm screwdriver to remove the 5.7 mm screw from the wheels.
    • A tool should have been provided in the box for this purpose.
  3. Enabot EBO SE Camera Replacement: Schritt 3, Bild 1 von 2 Enabot EBO SE Camera Replacement: Schritt 3, Bild 2 von 2
    • Pull the wheel assembly towards you so it comes straight off without resistance.
    • If there is resistance, make sure to apply gentle force when pulling as it can get damaged with too much force.
  4. Enabot EBO SE Camera Replacement, Lower Housing: Schritt 4, Bild 1 von 2 Enabot EBO SE Camera Replacement, Lower Housing: Schritt 4, Bild 2 von 2
    • Use a Torx screwdriver to remove the four 9 mm screws from the assembly.
  5. Enabot EBO SE Camera Replacement: Schritt 5, Bild 1 von 3 Enabot EBO SE Camera Replacement: Schritt 5, Bild 2 von 3 Enabot EBO SE Camera Replacement: Schritt 5, Bild 3 von 3
    • Use your fingernail to carefully press down and eject the Micro SD Card from the back of the Enabot.
    • Keep the Micro SD Card in a safe spot for later.
  6. Enabot EBO SE Camera Replacement: Schritt 6, Bild 1 von 2 Enabot EBO SE Camera Replacement: Schritt 6, Bild 2 von 2
    • Place the iFixit opening tool inside the Micro SD slot.
    • Very carefully apply pressure to the top of the slot and pry open the casing to separate the upper and lower housing.
  7. Enabot EBO SE Camera Replacement: Schritt 7, Bild 1 von 3 Enabot EBO SE Camera Replacement: Schritt 7, Bild 2 von 3 Enabot EBO SE Camera Replacement: Schritt 7, Bild 3 von 3
    • Using the iFixit opening tool or your fingernail, place it underneath the gray tab on the lower housing.
    • Lift the tab up and pull out the ribbon cable to disconnect it from the lower housing.
  8. Enabot EBO SE Camera Replacement: Schritt 8, Bild 1 von 3 Enabot EBO SE Camera Replacement: Schritt 8, Bild 2 von 3 Enabot EBO SE Camera Replacement: Schritt 8, Bild 3 von 3
    • There are two black and red wire connectors attached to the upper and lower housing.
    • Gently use your finger nails to lift up and disconnect both wires to fully separate the upper and lower housings.
  9. Enabot EBO SE Camera Replacement, Motherboard: Schritt 9, Bild 1 von 2 Enabot EBO SE Camera Replacement, Motherboard: Schritt 9, Bild 2 von 2
    • Use the iFixit opening tool to unlock the side gray tab and free the orange & black ribbon cable.
  10. Enabot EBO SE Camera Replacement: Schritt 10, Bild 1 von 2 Enabot EBO SE Camera Replacement: Schritt 10, Bild 2 von 2
    • Use the iFixit opening tool to unlock the middle gray tab and free the orange & black ribbon cable.
  11. Enabot EBO SE Camera Replacement: Schritt 11, Bild 1 von 3 Enabot EBO SE Camera Replacement: Schritt 11, Bild 2 von 3 Enabot EBO SE Camera Replacement: Schritt 11, Bild 3 von 3
    • Select one of the release tabs on the edge of the upper casing that holds the motherboard in place.
    • Place one finger in between the motherboard and the upper casing.
    • Pull the release tab back while lifting the motherboard with your other finger to "pop" the motherboard out of the casing.
  12. Enabot EBO SE Camera Replacement: Schritt 12, Bild 1 von 3 Enabot EBO SE Camera Replacement: Schritt 12, Bild 2 von 3 Enabot EBO SE Camera Replacement: Schritt 12, Bild 3 von 3
    • Use the ifixit opening tool to disconnect the blue & white ribbon cable.
    • Gently pull the blue & white ribbon cable out of the gray connector tab.
  13. Enabot EBO SE Camera Replacement, Camera: Schritt 13, Bild 1 von 3 Enabot EBO SE Camera Replacement, Camera: Schritt 13, Bild 2 von 3 Enabot EBO SE Camera Replacement, Camera: Schritt 13, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove all five 7.4 mm screws from the upper casing.
  14. Enabot EBO SE Camera Replacement: Schritt 14, Bild 1 von 2 Enabot EBO SE Camera Replacement: Schritt 14, Bild 2 von 2
    • Place your fingers in the space between the black casing and white lid.
    • Pull black casing towards you to separate the two parts.
  15. Enabot EBO SE Camera Replacement: Schritt 15, Bild 1 von 3 Enabot EBO SE Camera Replacement: Schritt 15, Bild 2 von 3 Enabot EBO SE Camera Replacement: Schritt 15, Bild 3 von 3
    • Remove the two 6 mm Phillips #00 screws on either side of the camera.
  16. Enabot EBO SE Camera Replacement: Schritt 16, Bild 1 von 3 Enabot EBO SE Camera Replacement: Schritt 16, Bild 2 von 3 Enabot EBO SE Camera Replacement: Schritt 16, Bild 3 von 3
    • Gently remove the camera until it comes out of the casing.
Abschluss
Oscar Parra
109 Reputation
1 Anleitung geschrieben
University of Memphis, Team 4-5, Sneed Spring 2024 Mitglied von University of Memphis, Team 4-5, Sneed Spring 2024
UM-SNEED-S24S4G5
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 10
Insgesamt: 72
