Einleitung
The lower housing is very important to your Enabot EBO SE since this is where the daughterboard, battery, and speaker are located. You will potentially need to replace them for your Enabot EBO SE to continue functioning correctly. We will take you step by step to replace these necessities and hopefully help you have a more pleasant experience.
Was du brauchst
Gently turn the robot upside down.
Place the robot on a stable surface to prevent it from rolling or falling.
Pull the wheel assembly towards you so it comes straight off without resistance.
Use a Torx screwdriver to remove the four 9 mm screws from the assembly.
Use your fingernail to carefully press down and eject the Micro SD Card from the back of the Enabot.
Using the iFixit opening tool or your fingernail, place it underneath the gray tab on the lower housing.
Lift the tab up and pull out the ribbon cable to disconnect it from the lower housing.
Gently use your finger nails to lift up and disconnect both wires to fully separate the upper and lower housings.
