Zum Hauptinhalt wechseln
Enabot EBO SE Speaker Replacement
Was du brauchst
  1. Enabot EBO SE Speaker Replacement, Wheel Assembly: Schritt 1, Bild 1 von 1
    • Gently turn the robot upside down.
    • Place the robot on a stable surface to prevent it from rolling or falling.
  2. Enabot EBO SE Speaker Replacement: Schritt 2, Bild 1 von 3 Enabot EBO SE Speaker Replacement: Schritt 2, Bild 2 von 3 Enabot EBO SE Speaker Replacement: Schritt 2, Bild 3 von 3
    • Use a flathead 2.5 mm screwdriver to remove the 5.7 mm screw from the wheels.
    • A tool should have been provided in the box for this purpose.
  3. Enabot EBO SE Speaker Replacement: Schritt 3, Bild 1 von 2 Enabot EBO SE Speaker Replacement: Schritt 3, Bild 2 von 2
    • Pull the wheel assembly towards you so it comes straight off without resistance.
    • If there is resistance, make sure to apply gentle force when pulling as it can get damaged with too much force.
  4. Enabot EBO SE Speaker Replacement, Lower Housing: Schritt 4, Bild 1 von 2 Enabot EBO SE Speaker Replacement, Lower Housing: Schritt 4, Bild 2 von 2
    • Use a Torx screwdriver to remove the four 9 mm screws from the assembly.
  5. Enabot EBO SE Speaker Replacement: Schritt 5, Bild 1 von 3 Enabot EBO SE Speaker Replacement: Schritt 5, Bild 2 von 3 Enabot EBO SE Speaker Replacement: Schritt 5, Bild 3 von 3
    • Use your fingernail to carefully press down and eject the Micro SD Card from the back of the Enabot.
    • Keep the Micro SD Card in a safe spot for later.
  6. Enabot EBO SE Speaker Replacement: Schritt 6, Bild 1 von 2 Enabot EBO SE Speaker Replacement: Schritt 6, Bild 2 von 2
    • Place the iFixit opening tool inside the Micro SD slot.
    • Very carefully apply pressure to the top of the slot and pry open the casing to separate the upper and lower housing.
  7. Enabot EBO SE Speaker Replacement: Schritt 7, Bild 1 von 3 Enabot EBO SE Speaker Replacement: Schritt 7, Bild 2 von 3 Enabot EBO SE Speaker Replacement: Schritt 7, Bild 3 von 3
    • Using the iFixit opening tool or your fingernail, place it underneath the gray tab on the lower housing.
    • Lift the tab up and pull out the ribbon cable to disconnect it from the lower housing.
  8. Enabot EBO SE Speaker Replacement: Schritt 8, Bild 1 von 3 Enabot EBO SE Speaker Replacement: Schritt 8, Bild 2 von 3 Enabot EBO SE Speaker Replacement: Schritt 8, Bild 3 von 3
    • There are two black and red wire connectors attached to the upper and lower housing.
    • Gently use your finger nails to lift up and disconnect both wires to fully separate the upper and lower housings.
  9. Enabot EBO SE Speaker Replacement, Battery: Schritt 9, Bild 1 von 3 Enabot EBO SE Speaker Replacement, Battery: Schritt 9, Bild 2 von 3 Enabot EBO SE Speaker Replacement, Battery: Schritt 9, Bild 3 von 3
    • Use the iFixit opening tool or your fingernail to disconnect the cable by placing the edge underneath the gray tab.
    • Flip the tab up and pull the ribbon cable out.
    • Disconnect the red and blue wires from the daughterboard by using your finger nails to pull up on the connector to disconnect.
  10. Enabot EBO SE Speaker Replacement: Schritt 10, Bild 1 von 3 Enabot EBO SE Speaker Replacement: Schritt 10, Bild 2 von 3 Enabot EBO SE Speaker Replacement: Schritt 10, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove both 7.4 mm screws from the side of the battery's casing.
  11. Enabot EBO SE Speaker Replacement: Schritt 11, Bild 1 von 2 Enabot EBO SE Speaker Replacement: Schritt 11, Bild 2 von 2
    • Pull the battery casing upwards from the lower half of the assembly to remove it.
  12. Enabot EBO SE Speaker Replacement: Schritt 12, Bild 1 von 2 Enabot EBO SE Speaker Replacement: Schritt 12, Bild 2 von 2
    • Carefully remove the battery from the casing in order to replace.
  13. Enabot EBO SE Speaker Replacement, Speaker: Schritt 13, Bild 1 von 3 Enabot EBO SE Speaker Replacement, Speaker: Schritt 13, Bild 2 von 3 Enabot EBO SE Speaker Replacement, Speaker: Schritt 13, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove each 7.4 mm screw from either side of the speaker.
    • Make sure to apply gentle force so it won't damage any other part of the Enabot EBO SE.
  14. Enabot EBO SE Speaker Replacement: Schritt 14, Bild 1 von 3 Enabot EBO SE Speaker Replacement: Schritt 14, Bild 2 von 3 Enabot EBO SE Speaker Replacement: Schritt 14, Bild 3 von 3
    • Remove the speaker from the battery casing.
Abschluss
Kevin H.
716 Reputation
5 Anleitungen geschrieben
University of Memphis, Team 4-5, Sneed Spring 2024 Mitglied von University of Memphis, Team 4-5, Sneed Spring 2024
UM-SNEED-S24S4G5
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 26
Letzte 30 Tage: 44
Insgesamt: 479
