Einleitung
Learn how to replace the filter of your Enagic Water filter SD501 Platinum to maintain its function with this filter replacement guide.
It is important to do this replacement since we would want to keep your water source as clean as possible. The filter should be always replace in 6-9 months. You can always make sure by marking the dates down.
Make sure you have prepared a brand new filter for steps 7 and 8 to replace the old one.
Before beginning, you might want to clean up the surroundings. You don’t want anything getting in your water filter machine.
Was du brauchst
Turn the ring at the bottom of the filter to the left until you hear a "click".
To change another filter, simply just follow the instructions once more.
