Einleitung
The batteries included in the packs are prone to failure and leaking. This guide will show you how to replace the batteries with better quality rechargeables.
Was du brauchst
Remove battery pack from the Wii Remote and locate the two screws between the batteries. Remove these and put them asside.
Using your fingernail or a small screwdriver, carefully separate the two halves of the battery casing. These aren't glued and should separate with little effort.
Remove the two batteries, noting their orientation.
Clean up any leaking battery acid and/or corrosion.
Once the contacts and compartment are clean, insert your new rechargeable batteries.
Re-insert the screws. The battery pack will only fit in one direction.
While you are at it, clean the outer contacts and bend them out a little. This can help eliminate remotes having poor battery life.
You should now have a working battery pack. Insert back into the Wii Remote and place on the charger. Allow it to get a good full initial charge in order to extend your battery life.
Enjoy your "non-reparable" repaired induction charging system.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Wow, that explains it. So many complaints about the energizer inductive batteries dying quickly. They take a product meant for two AA and replace it with two AAA's. Yep, that'll limit your playing time...
Easy to do! Just waiting to see if it will charge. If not, it was worth the shot. Thank you!
