Zum Hauptinhalt wechseln
Entry Door Weatherstripping Replacement
Was du brauchst
  1. Entry Door Weatherstripping Replacement, Weatherstripping: Schritt 1, Bild 1 von 2 Entry Door Weatherstripping Replacement, Weatherstripping: Schritt 1, Bild 2 von 2
    • Use the putty knife to loosen the weatherstripping from the groove.
    • Push outwards from the groove using the putty knife, so the groove doesn't get damaged.
    • The groove is located behind the exterior of the door frame
  2. Entry Door Weatherstripping Replacement: Schritt 2, Bild 1 von 3 Entry Door Weatherstripping Replacement: Schritt 2, Bild 2 von 3 Entry Door Weatherstripping Replacement: Schritt 2, Bild 3 von 3
    • Pull out the Weatherstripping from the groove
    • Use the putty knife if assistance is needed by pushing the weatherstripping outward from the groove
  3. Entry Door Weatherstripping Replacement: Schritt 3, Bild 1 von 1
    • After removing the weatherstripping, measure the door frame using the measuring tape.
  4. Entry Door Weatherstripping Replacement: Schritt 4, Bild 1 von 2 Entry Door Weatherstripping Replacement: Schritt 4, Bild 2 von 2
    • After measuring the door use a pen to mark the new weatherstrip and cut it with the scissors.
    • Be careful when handling scissors.
  5. Entry Door Weatherstripping Replacement: Schritt 5, Bild 1 von 2 Entry Door Weatherstripping Replacement: Schritt 5, Bild 2 von 2
    • Using the putty knife, push the new weatherstripping into the door groove.
  6. Entry Door Weatherstripping Replacement: Schritt 6, Bild 1 von 3 Entry Door Weatherstripping Replacement: Schritt 6, Bild 2 von 3 Entry Door Weatherstripping Replacement: Schritt 6, Bild 3 von 3
    • Repeat the process from steps 1-5 for the weatherstrip for the top and left of the doorframe.
  7. Entry Door Weatherstripping Replacement: Schritt 7, Bild 1 von 1
    • Now measure the door’s width using the measuring tape.
  8. Entry Door Weatherstripping Replacement: Schritt 8, Bild 1 von 2 Entry Door Weatherstripping Replacement: Schritt 8, Bild 2 von 2
    • Install the Door Sweep by drilling it in using a cordless drill.
    • Drill can be hazardous if not handled with care
Abschluss
Agilakumaran Shanmugalingam
157 Reputation
1 Anleitung geschrieben
York University, Team S1-G26, O'Regan Summer 2021 Mitglied von York University, Team S1-G26, O'Regan Summer 2021
YORK-O'REGAN-SU21S1G26
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 42
Letzte 30 Tage: 153
Insgesamt: 4,901
