Zum Hauptinhalt wechseln
Epiphone ES-335 PRO Tuner Replacement
Was du brauchst
  1. Epiphone ES-335 PRO Tuner Replacement, Strings: Schritt 1, Bild 1 von 2 Epiphone ES-335 PRO Tuner Replacement, Strings: Schritt 1, Bild 2 von 2
    • Using the tuner, loosen the string by turning the tuner.
    • Continue to loosen the string until it is easily unwrapped and pulled out of the tuner.
  2. Epiphone ES-335 PRO Tuner Replacement: Schritt 2, Bild 1 von 1
    • On the bridge of the guitar, push the string through the back until the other end is visible. Then grasp and pull the string all the way out.
  3. Epiphone ES-335 PRO Tuner Replacement, Tuner: Schritt 3, Bild 1 von 1
    • Using a phillips head #2 screwdriver, unscrew the two 1.0 mm length screws on the sides of the tuner.
    • Be sure to keep track of the screws if you are using them for the new tuner, unless the new tuner has screws of its own.
  4. Epiphone ES-335 PRO Tuner Replacement: Schritt 4, Bild 1 von 1
    • The tuner should come right out of the back of the head of the guitar.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 1,339
