Einleitung
Follow these steps to replace a faulty or broken tuner at the head of the Epiphone ES-335 PRO electric guitar. This component of the guitar can also be changed to upgrade the design of the guitar to your liking.
Was du brauchst
Using the tuner, loosen the string by turning the tuner.
Continue to loosen the string until it is easily unwrapped and pulled out of the tuner.
On the bridge of the guitar, push the string through the back until the other end is visible. Then grasp and pull the string all the way out.
Using a phillips head #2 screwdriver, unscrew the two 1.0 mm length screws on the sides of the tuner.
