Zum Hauptinhalt wechseln
Epomaker Shadow-X Switch Plate Re-alignment
Was du brauchst
  1. Epomaker Shadow-X Switch Plate Re-alignment, Switch Plate Replacement: Schritt 1, Bild 1 von 3 Epomaker Shadow-X Switch Plate Re-alignment, Switch Plate Replacement: Schritt 1, Bild 2 von 3 Epomaker Shadow-X Switch Plate Re-alignment, Switch Plate Replacement: Schritt 1, Bild 3 von 3
    • Power off the keyboard and disconnect any USB cable.
    • Place the keyboard on a clean, static-free workspace.
  2. Epomaker Shadow-X Switch Plate Re-alignment: Schritt 2, Bild 1 von 1
    • Use a keycap puller/spudger to remove all keycaps on the keyboard.
  3. Epomaker Shadow-X Switch Plate Re-alignment: Schritt 3, Bild 1 von 1
    • Remove the screws on the back of the keyboard with a hex screwdriver.
    • Carefully pry open the case using a plastic opening tool or spudger, and separate the top and bottom halves.
  4. Epomaker Shadow-X Switch Plate Re-alignment: Schritt 4, Bild 1 von 1
    • Locate the switch plate, which sits between the key switches and the PCB.
    • If the switch plate is misaligned, carefully adjust it so that it sits flush and aligns with all switch positions.
    • Ensure that each switch slot in the plate lines up with the PCB holes below it.
  5. Epomaker Shadow-X Switch Plate Re-alignment: Schritt 5, Bild 1 von 1
    • If the plate has screws or clips, check that each one is correctly fastened to prevent future misalignment.
    • Gently press on different sections of the plate to verify that it’s stable and correctly positioned over the PCB.
  6. Epomaker Shadow-X Switch Plate Re-alignment: Schritt 6, Bild 1 von 3 Epomaker Shadow-X Switch Plate Re-alignment: Schritt 6, Bild 2 von 3 Epomaker Shadow-X Switch Plate Re-alignment: Schritt 6, Bild 3 von 3
    • Reinsert each switch, ensuring that they align with both the switch plate and the PCB.
    • Snap the top and bottom halves of the case back together. Replace and tighten all screws.
    • Reinstall all keycaps and check that they are aligned and consistent in height.
Abschluss
You have successfully realigned the switch plate on your Epomaker Shadow-X keyboard! This adjustment improves switch stability and typing consistency. Check each key to confirm the alignment, and enjoy smoother, more consistent typing.
Beck Spitler
611 Reputation
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 19
Insgesamt: 175
